Is there an efficient way to check if a series exists in a database and then if it doesn't have eviews look in a different database?
if "series" exists in db1 then fetch it
if not fetch from db2
something like that?
Check if series exists in database
Re: Check if series exists in database
Only with using the query command
That actually helped a lot, thanks gareth. I was able to use @wquery to achieve what I needed. This is unrelated, but when you are using logmsg to post messages, is there anyway to force them all into one line. For example
logmsg Hi
logmsg my
logmsg name
logmsg is
logmsg Fred
to display as
"Hi my name is Fred" opposed to
my
name
is
Fred
logmsg Hi
logmsg my
logmsg name
logmsg is
logmsg Fred
to display as
my
name
is
Fred
Only by putting them into one string then sending that one string to logmsg
