Question on GMM estimation
andwes
Postby andwes » Wed May 16, 2018 2:15 pm
Im trying to estimate an equation in the attached file using GMM (the file provides a simplified example of when I run into problems. However, when I‎ use both current and lagged variables (lproductivity_manufact) as independent variables (also added as instruments) i get an error message that the order condition is violated (Order condition violated - Insufficient instruments). When I use only the curent value, everything works fine. I guess i must be doing something wrong, but cannot figure out what is the problem. If anyone knows what is the problem, please let me know.
Best,
Andreas
wage_formation_code_test_file.prg
(1.19 KiB) Downloaded 361 times
sweout.xls
(12.41 KiB) Downloaded 349 times
Re: Question on GMM estimation
Postby startz » Wed May 16, 2018 4:17 pm
You can't have fewer instruments than coefficients.
