Internal Error 512
Internal Error 512
Hey, I wonder what "Internal Error 512" menas. Thanks, Fabio
Re: Internal Error 512
It means something happened that shouldn't have. Could you provide details as to what you were doing when it occurred. It probably means you've found a bug.
Well, I was running some thousands OLS and storing their @r2, etc. in a table. Sometimes I store just those with a R2 >= k (e.g., k = 0.80). I get this quite often.
I thought that might have happened because I defined a table with more than one million rows. Or perhaps because I have erased a hidden file.
Thank You, Fabio
Thank You, Fabio
Are you getting this error on a save or an open?
Mostly when I open a workfile, specially those that are large (couple hundreds of Mb).
Sometimes I leave the code running about, say, some thousands OLS or VAR and keep saving every couple of hundred iterations (both the workfile and a table with output - with wfsave and table.save).
When I am back to work in the next morning, I get this error. Today, I just got "Internal Error 520".
I dont know if this is related, but what is this "~f1" file? It is just as large as teh original ".wf1" file!
It's just the backup of the previous version of the workfile from the last time you saved.
Then, if I am running Eviews 6, I can delete the file, right? How about the 512/520 error?
It is quite annoying, for I have to leave the program running for hours and I might end up with an unreadable 500Mb workfile!
Thank You, Fabio
Thank You, Fabio
Yes, you can delete the .~f1 file. Mind you, if EViews is misbehaving having an extra backup around might be a good idea. :)
I think we'd have to see it in order to work out what is going wrong.
Could you send us your program and data?
Gareth, sorry, but I can't post neither code, workfile or data.
But the code runs about one milliion VARs changing series (log, dlog, @pcy, etc.), lags, etc. and retrieving in a table object some key statistics (like @rbar, @dw and var01.c(i,j)).
Thanks, Fabio
Thanks, Fabio
Without the program/data it will be hard for us to diagnose precisely. At a guess, you're simply pushing the limits of what can be held in a table. You might contemplate putting information into multiple tables rather than one big one.
What is the limit of a table? One million rows?
Complicated question with no real answer, as it depends on too many different factors.
