Equation Output Comment
pcruz_cc
Postby pcruz_cc » Tue Apr 10, 2018 8:14 am
Hello, Is it a way to write a description or label at the top of the estimation output of an equation?
I am working with a lot of different equations and a lot of series (351). For coding simplicity, each serie is named ser{!x}, with !x=1 to 351 and have an atribute ("product") to identify it. However, when making estimations I always have to go to the serie's label to know which product Im estimating. It would be much easier if the estimation output show directly in the top the dependent variable attribute as a comment. Any hints?
Re: Equation Output Comment
Postby EViews Gareth » Tue Apr 10, 2018 9:15 am
You can't change the equation output directly. You could freeze the output into a table object and then modify the contents of that table.
