Save Var results in a scalar, matrix,etc.
lpando08
Postby lpando08 » Thu Apr 05, 2018 1:46 pm
Hi everyone!
I have run a VAR and I would like to know if there is exist a way to save the results, exactly the sum of squared residuals that appears in the window of VAR estimation outputs. I want to save that number in a scalar or matrix. Is there a command or a way to do this?
Thank you for your answers!
EViews Matt
Re: Save Var results in a scalar, matrix,etc.
Postby EViews Matt » Thu Apr 05, 2018 1:59 pm
Take a look at the VAR object documentation. I believe the @ssr data member is what you're looking for.
lpando08
Postby lpando08 » Thu Apr 05, 2018 2:04 pm
Hi, yes. I have tried to used it but I cant, do yo have any example where I can use this command running a VAR? I tried to used this commad after running the VAR but the programm says that there is no a equation especified.
EViews Matt
Postby EViews Matt » Thu Apr 05, 2018 2:56 pm
You need to specify which VAR equation's SSR you want, e.g., @ssr(1), @ssr(2), etc.
lpando08
Postby lpando08 » Thu Apr 05, 2018 3:12 pm
Only a last question please, if I have 2 vars: var 1 and var2, the first with 3 equations and the second with 4. Is there any way to save the total ssr generated, I mean in this case to save the seven ssr that would be generated? and then to find the minimun of them?
EViews Matt
Postby EViews Matt » Thu Apr 05, 2018 3:30 pm
Sure, a few loops can easily go through any number of VARs you wish with any number of equations per VAR:
!k = 1 for %v var1 var2 for !i = 1 to {%v}.@neqn vector(!k) ssr(!k) = {%v}.@ssr(!i) !k = !k + 1 next next scalar min_ssr = @mins(ssr, 1)
lpando08
Postby lpando08 » Thu Apr 05, 2018 4:38 pm
Hello, thank you very much for your answer but I think I made a mistake and this was not what I was looking for :(. Actually, I have this a var_{%grp} that goes from var_1 to var_n, each of them have différent number of équations. What I want to do is for each équation of each var ( from var_1 to var_n) save the ssr’s and then for each var find the minimun ssr. I mean have the minimun ssr for each var.
Thank you very much for your answer!
EViews Matt
Postby EViews Matt » Fri Apr 06, 2018 8:48 am
Something like this...
!m = 1 for !i = 1 to <fill in n> !k = 1 for !j = 1 to var_!i.@neqn vector(!k) ssr(!k) = var_!i.@ssr(!j) !k = !k + 1 next !tmp = @mins(ssr, 1) vector(!m) min_ssr(!m) = !tmp !m = !m + 1 next
The minimum SSRs are stored in vector min_ssr.
lpando08
Postby lpando08 » Sat Apr 07, 2018 9:31 pm
Thank you very much!
