Hello.
I've eviews10 student version.I can't use ARDL because i've 9 serials and the programme tell me " singular matrix".why ? and where is the probleme ?
Thank you for your answers
eviews student and ARDL
Re: eviews student and ARDL
Quite likely you have perfect multicollinearity. If you post exactly what you did someone may be able to give more detailed advice
thank you.
i've 8 independent variables and one dependant.I've the periode of 15 years.My serials are a stationnarity in I(0) and I(1).
When i clic in ARDL and choose 2 lags or any other number,the programme no fonctionne and the text is "error message.....singular matrix".
excuse my english if its bad
I believe the problem is that you have too many lagged variables for the number of observations available.
in this condition i must to show the existence of multicollinearity and remove it later to be able to use ARDL.This is it ?
or another sotluion ,
I will study each independent variable with the dependent variable, it would be better.
No, the only real answer is to get more data.
Thanks for your help.
I still have the same problem, or it is little or it is too important. In both situations I have nothing
You can't have more series (lagged or otherwise) than you have data points. If you've been able to increase your sample to substantially more than 15 points and you're still having trouble, you might want to post your workfile and details of what you've done to see if someone can catch something.
I can't go beyond 15 years, the data is limited.
Then I suspect you can't have a model with 9 variables. I know that's frustrating, but regressions aren't magic.
the problem is especially in the duration of 15 years and not the software.
