Import a large number of excel files
RDS
Postby RDS » Wed Mar 21, 2018 1:45 am
I need to import a large number of excel files with sheets numbered from 1_ to 100_
Is there an efficient way to import them?
The tentative approaches below give me an error
for !i = 1 to 100
read(e,c2,s={!i}_) OECD_CLI_EA.xls CLI_{!i}
for !i = 1 to 100
read(e,c2,s=!i_) OECD_CLI_EA.xls CLI_!i
Nom
Re: Import a large number of excel files
Postby Nom » Wed Mar 21, 2018 2:47 am
Hi, I'm sorry I am not answering your question but I want to ask for your help. I am a new user on this forum and I would like to post up a question but I do not know how or where to do this. Where do I click? Which icon? Thank you
Postby EViews Steve » Wed Mar 21, 2018 7:43 am
for !i = 1 to 100
for !i = 1 to 100
Use our IMPORT command instead.
Just drag one excel file onto the EViews window to start the import wizard. Once you've successfully imported one sheet from the file, look at the IMPORT command that was captured in the captured window and use it as a template for your program.
Postby EViews Steve » Wed Mar 21, 2018 7:47 am
Once you've entered a forum group page (such as this Programming group), simply click the "New Topic*" button. It looks like this:
RDS
Postby RDS » Wed Mar 21, 2018 9:51 am
Steve,
I am not sure I understand your point.
I have imported the first file
import OECD_CLI_EA.xls range="1_!c2:c187" @smpl {%startdate2} {%lastdate} @rename series01 cli_AT
Is there a loop I can create around range="1_!c2:c187"
Postby EViews Gareth » Wed Mar 21, 2018 9:56 am
for !i=1 to 100 %range = @str(!i)+"_!c2:c187" import OECD_CLI_EA.xls range=%range @smpl {%startdate2} {%lastdate} @rename series01 cli_AT next
or something similar.
RDS
Postby RDS » Wed Mar 21, 2018 10:20 am
Import is not stable: Eviews crashes.
I continue to prefer read
for %series 1 2 3 4 5 6 7 8 9 10 11 12 13
read(e,c2,s={%series}_) OECD_CLI_EA.xls CLI_{%series}
rename cli_1 cli_AT
rename cli_2 cli_BE
rename cli_3 cli_DE
rename cli_4 cli_EA
rename cli_5 cli_ES
rename cli_6 cli_FI
rename cli_7 cli_FR
rename cli_8 cli_GR
rename cli_9 cli_IE
rename cli_10 cli_IT
rename cli_11 cli_NL
rename cli_12 cli_PT
rename cli_13 cli_US
Postby EViews Steve » Wed Mar 21, 2018 4:35 pm
What version of EViews are you using? And the build date? Mind posting one of your spreadsheets?
Nom
Postby Nom » Tue Mar 27, 2018 3:51 am
thank you Steve
