datenext bug
radmirer
datenext bug
Postby radmirer » Tue Mar 20, 2018 7:27 am
I found that datenext is not working properly using monthly data. For example, while the first command below gives the correct result on my comupter, the command below does not. I was able to reproduce this on other computers as well:
show @datenext(@dateval("1995M01"), "mm")
show @datenext(@dateval("2000M03"), "MM")
Regards
Re: datenext bug
Postby EViews Gareth » Tue Mar 20, 2018 7:31 am
What result did it give you that was incorrect?
I just ran it on my PC and it gave the correct date (2000/04/01)
smr01
Re: datenext bug
Postby smr01 » Tue Mar 20, 2018 9:56 am
It seems to only be an issue with M3, M6, M9 and M12
M3 gives me 2000Q2, M6 200S2 M9 2000Q4 and M12 2001
smr01
Re: datenext bug
Postby smr01 » Tue Mar 20, 2018 10:00 am
Oops using EViews 10 Enterprise March 15 2018 build
Re: datenext bug
Postby EViews Gareth » Tue Mar 20, 2018 10:12 am
Note that the function will return a date. As in a single day.
2000Q2 is the same thing as 2000M6, which is the same thing as 2000/06/01.
If you would like the result shown in a different date format, change the display format in which you are displaying the date.
