Hi, I have two tables with the same number of columns.
I would like to copy all the data from table 2 to table 1 at the last row of table 1.
I tried this code by in vain.
Scalar x =@rows(table1)+1
table2.copyrange table1 A&x.
Can someone help me out for this code?
Otherwise if there any way to merge horizontally two tables of same dimensions.
Thanks.
Help for tableTdate.copyrange tableTdate1
EViews Matt
Re: Help for tableTdate.copyrange tableTdate1
It appears you've confused the syntax of copyrange and copytable. Within a program you could use:
Outside a program, manually entering commands, you could use:
!x = @rows(table1) + 1
table2.copytable table1 A!x
string s = "A" + @str(@rows(table1) + 1)
table2.copytable table1 {s}
