math functions for coef
maxchen
Postby maxchen » Tue Dec 02, 2008 4:03 am
It seems that math functions do NOT support coefficient vector. For example
wfcreate u 4 coef(3) c1 = 1 coef(3) c2 = 2 c2 = exp(c1) 'error
Re: math functions for coef
Postby EViews Gareth » Tue Dec 02, 2008 8:25 am
coefficient vectors aren't really intended to be used for calculations etc..., so yes, math functions will not work upon them.
Postby EViews Glenn » Tue Dec 02, 2008 1:27 pm
But it's easy enough to get your coef into a vector object with which you can use functions:
coef(2) c1 c1.fill 1, 2 vector c2 = c1 vector c3 = exp(c2)
maxchen
Postby maxchen » Tue Dec 02, 2008 4:10 pm
thanks
yeah, by coef -> vector ->coef, for I use coef in LogL. Once the estimation of Logl is succeeded, I use another Logl where the parameter transformation inside Logl is remove, and I transform the result as the starting value to estimate the new Logl.
