Error @rapplyranks: vector sent to function which operates on a matrix.
andrejs
Postby andrejs » Sat Feb 24, 2018 11:22 am
would someone please help me with @rapplyranks command error, am I missing something in the syntax?
As a simple example, I have 10x5 matrix A at and 5x1 vector F at hand. Following the manual on @rapplyrank, I then run:
matrix d = @rapplyranks(a,f)
Which produces the following error: vector sent to function which operates on a matrix.
Im a bit confused - what vector instead of matrix? Isn't it according to syntax where first paramater A is a matrix and second parameter f is a vector?
[Please see attached the very simple workfile, in case it helps to clarify]
Thank you in advance,
Andrejs
rapply.WF1
(11.82 KiB) Downloaded 251 times
Re: Error @rapplyranks: vector sent to function which operates on a matrix.
Postby EViews Gareth » Sun Feb 25, 2018 9:56 pm
What's the build date and version of EViews (Help-About EViews)?
andrejs
Postby andrejs » Mon Feb 26, 2018 12:18 am
Its Eviews 10, Jun 26 2017 build.
Might it be the case that something has changed in @rapplyranks syntax?
Postby EViews Gareth » Mon Feb 26, 2018 5:23 am
Update to the latest version.
andrejs
Postby andrejs » Mon Feb 26, 2018 6:25 am
Thanks, it solved the issue!
Have a nice day,
Andrejs
