Hi all, I am newbie in e-views
I have an excel with three (numeric values) columns.
I import successfully the data creating three objects (A,B,C) and I want to modify the data in the
C object keeping rows with values larger than 2.6.
Could you please help me how can I do it ?
(Either with command or graphically)
I suppose that all the objects should be modified as group.
Thanks a lot for your assistance
Transforming data (keep values only larger than 2.6)
Re: Transforming data (keep values only larger than 2.6)
You'll have to be more precise. What do you want to do with observations where C is not > 2.6?
I have made a linear regression first (ls A con B C)You'll have to be more precise. What do you want to do with observations where C is not > 2.6?
and I would like to make the transformation to C data in order to make a second regression ((ls new_A con new_B new_C)) and compare the results.
I have attached the initial data in excel file (data.xls) and the data I want after the transformation.
- new_data.xls
- (25.5 KiB) Downloaded 400 times
- data.xls
- (28.5 KiB) Downloaded 408 times
It still is really unclear as to what you want to do.
But I'm going to guess you just want to set the sample so that c>2.6
Yes , I want to keep only the values larger than 2.6 in the third variable object (column C)It still is really unclear as to what you want to do.
So set the sample such that c>2.6
