Programming a table
miorinnovo
Re: Programming a table
Postby miorinnovo » Thu Feb 01, 2018 2:50 pm
Gareth, you, Sir, are the man.
Postby EViews Gareth » Thu Feb 01, 2018 3:14 pm
Beer donations can be sent to support@eviews.com :D
miorinnovo
Postby miorinnovo » Fri Feb 02, 2018 2:20 pm
Here's another table question.
I was hoping to have the first column in my table be the names in my for string. But if I put {%string} in brackets to tell the table to read it It just displays {%string}. Is there a workaround for this?
Postby EViews Gareth » Fri Feb 02, 2018 2:40 pm
Don't follow.
miorinnovo
Postby miorinnovo » Fri Feb 02, 2018 3:05 pm
Here's the code
for %names a b c d e f !row = !row + 1 {%table}(!row,1) = "{%names}" {%table}(!row,2) = @mean({%names}{%somethingelse})
So I was hoping to get the first column to be rows that say "a" then next row says "b" etc. But they all just actually say {%names}.
also I want the second column to give me the mean of a{%somethingelse}
Postby EViews Gareth » Fri Feb 02, 2018 3:16 pm
{%table}(!row,1) = %names
miorinnovo
Postby miorinnovo » Fri Feb 02, 2018 3:22 pm
ok, that one hurt.
thanks
JimForest
Postby JimForest » Mon Jan 28, 2019 2:23 pm
I want to freeze and rename, can it be done in two lines?
equation eq6.ls(optmethod=opg) depvar c
freeze eq6.ls equation1
(and rename it as a table called equation1)
When I run above it won't accept the name. I get an error when I run RENAME in a separate line.
I am sure this is very simple.
Postby EViews Gareth » Mon Jan 28, 2019 6:17 pm
freeze(equation1) eq6.ls
