Dummy variables: Creating by mapping to an Alpha series.
Vladimir_Yorrick
Postby Vladimir_Yorrick » Wed Jan 27, 2010 10:41 pm
I am using EViews 7.
In an undated workfile with range = 15 I have an alpha series named Country:
Country = {AUT, AUT, AUT, BLX, BLX, BLX, BLX, BGR, BGR, CYP, CYP, CYP, CYP, CYP, CZE}.
Is there an easy way for me to create the following five dummies?
d_AUT = {1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
d_ BLX = {0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0}
d_BGR = {0, 0, 0, 0, 0, 0, 0, 1, 1, 0, 0, 0, 0, 0, 0}
d_CYP = {0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 0}
d_CZE = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1}
The commands below don't work but I hope it shows what I'm trying to do:
for %ctr AUT BLX BGR CYP CZE
series d_{%ctr} = stick a one in the same element when @elem(Country) = {%ctr}
or
series d_{%ctr} = @recode(Country = {%ctr},"1","0")
Thanks in advance for any suggestions.
Vlad.
Re: Dummy variables: Creating by mapping to an Alpha series.
Postby EViews Gareth » Thu Jan 28, 2010 8:33 am
The best way is probably just to make an automatic group from them:
group g @expand(country)
Vladimir_Yorrick
Postby Vladimir_Yorrick » Fri Jan 29, 2010 12:55 am
Thanks Gareth.
I'm still having some problems with this.
FYI, my alpha series Country is a lot larger than 15 observations and contains country codes that are not listed in alphabetical order.
After creating the group g, the group members will be:
CODE="AUT"
CODE="BLX"
CODE="BGR"
CODE="CYP"
CODE="CZE"
How would I then:
- create 5 series objects
- where each series is equal to the appropriate 'column' of the group
- and have each series automatically named d_AUT, d_BLX, d_BGR, d_CYP and d_CZE?
If these commands
for !i = 1 to 5
series d_{g.@seriesname({!i})} = g({!i})
were to work (which they don't) I would end up getting series with names like:
d_CODE="AUT"
d_CODE="BLX",
etc.
Vlad.
Postby EViews Gareth » Fri Jan 29, 2010 9:03 am
Your original code, with a tweak, might be the way to go then:
series d_{%ctr} = @recode(Country = %ctr,1,0)
Vladimir_Yorrick
Postby Vladimir_Yorrick » Mon Feb 01, 2010 11:03 pm
Thanks Gareth, that worked.
Vlad.
