Appending date ids - possible?
terrya
Postby terrya » Fri Apr 14, 2017 6:22 pm
I want to write a programme to retrieve and append two excel files from the internet that have two different but consecutive date ids. Is it possible to append the two date ids to form a single date id? I can download the two files and combine them manually for the analysis but I want to avoid this if possible.
Re: Appending date ids - possible?
Postby EViews Gareth » Fri Apr 14, 2017 6:27 pm
You'll have to be more specific.
But in general, yes it is possible.
terrya
Postby terrya » Fri Apr 14, 2017 8:36 pm
HI
They're 2 files on the website of the Reserve Bank of NZ (http://www.rbnz.govt.nz/-/media/Reserve ... -daily.xls
and http://www.rbnz.govt.nz/-/media/Reserve ... 9-2013.xls). I want to download the 1999-2013 data and then append the second). I have no problem downloading either using an EViews programme but I want to get the data into a single workfile, including all the analyses I want to do. I want the combined ids to provide a single sequence of dates.
Postby EViews Gareth » Fri Apr 14, 2017 9:14 pm
wfopen(type=excel) http://www.rbnz.govt.nz/-/media/ReserveBank/Files/Statistics/tables/b1/hb1-daily.xls import(type=excel, resize, mode=u) http://www.rbnz.govt.nz/-/media/ReserveBank/Files/Statistics/tables/b1/hb1-daily-1999-2013.xls
terrya
Postby terrya » Fri Apr 14, 2017 9:40 pm
Thanks.
As you know, it works. Perhaps others with this dilemma will get this help.
terrya
Postby terrya » Thu Dec 28, 2017 4:49 pm
Since I posted this, the RBNZ has changed to xlsx files. I've tried to modify the procedure suggested above but can get only the data 1999-2013. Is there a way around this?
Postby EViews Jason » Mon Jan 08, 2018 5:49 pm
The xlsx file was not created by Excel and parts of it does not match the expected format.
If you resave the hb1-daily.xlsx file using Excel, EViews will read the file correctly.
terrya
Postby terrya » Mon Jan 08, 2018 9:31 pm
Thanks that's precisely what I want to avoid. I used to do this.
Anyway, I can get the data via an R script. I want to get the data directly into an Eviews programme since for what I want to do is done far better in Eviews.
Also, I doubt that the files aren't Excel files.
There is a problem with https which I got around before by just dropping the s for the xls files.
Postby EViews Gareth » Mon Jan 08, 2018 9:34 pm
Your best bet is to contact the provider and ask them to fix their Excel making process - it has a bug.
terrya
Postby terrya » Mon Jan 08, 2018 9:58 pm
Thanks. I was intending to ring tomorrow (our time) to ask whether there's a problem with their files. However,as I indicated earlier, there appears to be no problem with reading the files into R. And your procedure with xls files worked really well.
Postby EViews Gareth » Mon Jan 08, 2018 10:03 pm
If you're going to speak to them, you can give them precise details.
If you download the two files and .xlsx and rename them to .zip you can then unzip them (.xlsx files are just zip files). Inside the zip folder there is an XL->Worksheets folder.
Download notepad++ (or any other good raw text editor) and open up the sheet1.xml file from both original files.
You'll notice the problem file (hb1-daily) has a single line - the xml data [the part following the <worksheets> tag] is on the same line as the xml specification line.
For the file that isn't a problem (hb1-daily-1999-2013), you'll notice that the <worksheets> tag is below the xml spec line.
terrya
Postby terrya » Mon Jan 08, 2018 10:11 pm
Thanks for this. It'll be very helpful as I really don't know anything about the inner workings of excel.
Postby EViews Jason » Tue Jan 09, 2018 10:16 am
Actually the entire file being a single line is not the issue (I incorrectly told Gareth this). There are incorrect and missing tag in the worksheet.xml files. For example the data ranges for each sheet were incorrect and the column range for each row were also not to spec. If you like, you can have them contact me jason@eviews.com and I can tell them more specifically what is wrong and which tags we expect that are missing.
Users browsing this forum: redversjones and 2 guests
