I would like to extract the specific observation valur (for a given cross-section for a given year) for the variable from the panel data workfile.
How can I do it? @elem command does not work and I cannot find any substitute command for panels. I am pretty sure there must be an easy way around it
I use e-views 6
Many thanks,
Artur
@elem (specific observation value) for panel data
aradziwill
Re: @elem (specific observation value) for panel data
Unfortunately, and surprisingly, there isn't an easy way to do it. I usually do something like setting the sample to be the one observation you want, then setting my scalar equal to the maximum of the series (since the maximum of a single value is just that single value!). Something along the lines of:
Which sets P equal to the value of X in year 1990 for cross-section 3.
smpl 1990 1990 if @crossid=3
scalar p = @max(x)
aradziwill
Thanks a lot, this works very well, although the lack of such command is indeed surprising
Artur
Artur
