I have to work with Eviews for a course in university (for the first time).
The first one was not a problem, but the regressiono with white standard errors doesn't work/I can't figure it out after trying it for hours.
Run regression for the whole sample: (*) log(gsp) = a + b_1*log(emp) +
b_2*log(p_cap). Report estimation results (print screen etc.) and analyze them.
Run the above regression again using White standard errors.
This is the way I tried it:
Quick -> Estimate Equation -> this is my specification: loggsp c logemp logp_cap -> estimation settings: ROBUSTLS -> then I want to change the options, but there is no field, where I can choose "Heteroskedasticity Consistent Covariance" or White or something like that.. Did I choose the right fields? What do I have to change?
The data are panel data (years from 1970-1986 in 48 different states). I hope you have enough information to help me!
I'm really desperated and I hope someone can help me! Thanks a lot in advance! :)
Re: White standard errors
Use Least Squares, not Robust LS.
Thanks. But where can I choose the white standard errors than?
The options tab.
Coef covariance
Which ever one you want. Since you want White, it would be one of the White ones.
