Perron (1989) Breakpoint Unit Root Test
For posting your own programs to share with others
NicolasR
Postby NicolasR » Fri Nov 03, 2017 10:31 am
The following code perform the Perron (1989) unit root test for time series with structural breaks. In the code the case 1 is defined as a level break, case 2 as a trend break and case 3 as a leven and trend break.
'Nicolas Ronderos Pulido '-------------------------------------------------------Inputs--------------------------------------------------- !quiebre=300 'Break date %series="ser02" 'Series object !lags=20 'Maximim lag %info_criteria="aic" 'schwarz, aic or hq !caso=2 'case 1,2 or 3 !significancia=0.1 '0.01,0.025,0.05 y 0.1 '------------------------------------------------------------------------------------------------------------------ genr d_t=0 genr du=0 genr d_tb=0 for !t=1 to @obsrange if !caso=1 or !caso=3 then if !t=!quiebre+1 then d_t(!t)=1 'Cambio en la tendencia en solo un momento del tiempo - D(TB)t d_tb(!t)=1 endif endif if !t>!quiebre then if !caso=2 then d_t(!t)=!t-!quiebre 'Cambio en la pendiente - DT*t else if !caso=3 then d_t(!t)=!t ' Cambio en la pendiente y en el nivel - DTt endif endif du(!t)=1 ' DUt endif next for !i=1 to !lags %lag=@str(-!i) %lags=%lags+"@d("+%series+"("+%lag+"))" if !caso=3 then equation caso_!caso.ls {%series} c du @trend d_t {%series}(-1) d_tb {%lags} else equation caso_!caso.ls {%series} c du @trend d_t {%series}(-1) {%lags} endif vector(!lags) information_criteria(!i)=@{%info_criteria} next for !i=1 to !lags %lag_=@str(-!i) %lags_=%lags_+"@d("+%series+"("+%lag_+"))" if information_criteria(!i)=@min(information_criteria) then if !caso=3 then equation caso_!caso.ls {%series} c du @trend d_t {%series}(-1) d_tb {%lags_} else equation caso_!caso.ls {%series} c du @trend d_t {%series}(-1) {%lags_} endif exitloop endif next scalar t=(c(5)-1)/@stderrs(5) scalar lamda=!quiebre/@obsrange scalar caso=!caso scalar significance=@floor(100*!significancia) scalar cv call cv(lamda,caso,significance,cv) if !caso=1 then if cv<t then @uiprompt("Unit root with level change") else @uiprompt("No unit root") endif endif if !caso=2 then if cv<t then @uiprompt("Unit root with drift change") else @uiprompt("No unit root") endif endif if !caso=3 then if cv<t then @uiprompt("Unit root with level and drift change") else @uiprompt("No unit root") endif endif subroutine local cv(scalar lamda,scalar caso,scalar significance,scalar cv) genr lamdas_=NA lamdas_.fill 0.1,0.2,0.3,0.4,0.5,0.6,0.7,0.8,0.9 stom(lamdas_,lamdas) vector(9) nearby=@abs(lamdas-lamda) for !i=1 to 9 if nearby(!i,1)=@min(nearby) then !position=!i endif next genr critical1=NA genr critical2=NA genr critical5=NA genr critical10=NA if caso=1 then critical1.fill -4.30,-4.39,-4.39,-4.34,-4.32,-4.45,-4.42,-4.33,-4.27 critical2.fill -3.93,-4.08,-4.03,-4.01,-4.01,-4.09,-4.07,-3.99,-3.97 critical5.fill -3.68,-3.77,-3.76,-3.72,-3.76,-3.76,-3.80,-3.75,-3.69 critical10.fill -3.40,-3.47,-3.46,-3.44,-3.46,-3.47,-3.51,-3.46,-3.38 stom(critical1,critical_1) stom(critical2,critical_2) stom(critical5,critical_5) stom(critical10,critical_10) endif if caso=2 then critical1.fill -4.27,-4.41,-4.51,-4.55,-4.56,-4.57,-4.51,-4.38,-4.26 critical2.fill -3.94,-4.08,-4.17,-4.2,-4.26,-4.2,-4.13,-4.07,-3.96 critical5.fill -3.65,-3.8,-3.87,-3.94,-3.96,-3.95,-3.85,-3.82,-3.68 critical10.fill -3.36,-3.49,-3.58,-3.66,-3.68,-3.66,-3.57,-3.5,-3.35 stom(critical1,critical_1) stom(critical2,critical_2) stom(critical5,critical_5) stom(critical10,critical_10) endif if caso=3 then critical1.fill -4.38,-4.65,-4.78,-4.81,-4.9,-4.88,-4.75,-4.7,-4.41 critical2.fill -4.01,-4.32,-4.46,-4.48,-4.53,-4.49,-4.44,-4.31,-4.1 critical5.fill -3.75,-3.99,-4.17,-4.22,-4.24,-4.24,-4.18,-4.04,-3.8 critical10.fill -3.45,-3.66,-3.87,-3.95,-3.96,-3.95,-3.86,-3.69,-3.46 stom(critical1,critical_1) stom(critical2,critical_2) stom(critical5,critical_5) stom(critical10,critical_10) endif !significance_=significance scalar cv=critical_!significance_(!position) endsub '------------------------------------------------------------------------------------------------------------------
References
Perron, P. (1989). The great crash, the oil price shock, and the unit root hypothesis. Econometrica: Journal of the Econometric Society, 1361-1401.
Return to “Program Repository”
