SUR estimation for shares that sum up to 1
jacarandas
Postby jacarandas » Tue Oct 31, 2017 11:37 pm
I am trying to estimate and forecast a system of market shares equations (J) with the same RHS exogenous regressors. As the market shares sum up to 1, I will be dropping one equation and estimating J-1 equations instead.
The EViews help manual says that "since the system of equations may contain cross-equation restrictions on parameters."
So, I am wondering if a constraint stating that all market shares sum up to 1 needs to be imposed. And, if so, how should this constraint be written out?
I am using EViews 10.
Any help would be much appreciated.
Thanks!
Re: SUR estimation for shares that sum up to 1
Postby EViews Gareth » Wed Nov 01, 2017 7:48 am
If you have alpha, beta and gamma and you want to impose that they sum to 1, just rewrite them as alpha, beta and (1-alpha-beta).
jacarandas
Postby jacarandas » Wed Nov 01, 2017 12:34 pm
Thanks Gareth!
Do I have to drop the Gamma equation as alpha, beta and gamma sums up to 1 in my SUR estimation?
So, is this what I end up estimating?
model.append alpha = my usual regressors
model.append beta = my usual regressors
model.append @identity gamma = 1-alpha-beta
Won’t gamma be an identity then, which SUR won’t allow?
OR
model.append 1-alpha-beta = my usual regressors
Thanks!
Postby EViews Gareth » Wed Nov 01, 2017 12:42 pm
Ah, sorry, I thought you wanted the coefficients to sum to one, not the variables. I’m now not sure I understand what you are trying to do
jacarandas
Postby jacarandas » Wed Nov 01, 2017 1:57 pm
Hi!
I’m trying to estimate a SUR system of market shares. But, as they sum up to 1, I know I’ve to drop an equation to avoid singularity. But, in doing so,
- should I impose a constraint in the system such that the shares still add up to 1, even though I’ve dropped an equation out.
- I’ve tried dropping different shares equations out. To get the remaining share that’s dropped out, I’ve just used 1- sun(shares forecasts from system). But, the remaining share forecast is always different depending on what’s dropped out. I’ve thought it’ll be the same as I’ve the same regressors.
jacarandas
Postby jacarandas » Sun Nov 05, 2017 6:54 pm
Hi! Just wondering it’ll be able to get some help on this:
- I’ve Alpha, beta and gamma shares that add up to 1. I have the same explanatory variables for all of them plus one variable specific to each of the shares.
- to avoid the singularity issue, I dropped one equation. But I realise my results change depending on which equation I drop. Why? When I drop alpha, what I did to get the forecast alpha share is 1- beta - gamma.
- are there restrictions I should place in a SUR system like this to estimate these equations? And how can I do that? I’ve read a few articles on electrical parties and goods market shares where authors have excluded one equation to avoid singularity but no mention of restrictions to be placed.
Any help will be great. Thanks.
jacarandas
Postby jacarandas » Wed Nov 15, 2017 2:01 pm
Hi Gareth,
Just wondering if you understand what I am trying to do now. See posts below?
Thanks!
Postby EViews Gareth » Wed Nov 15, 2017 2:12 pm
I do not. But someone might.
