fail arch test > 1 lag program
mkwazi
Postby mkwazi » Fri Jul 14, 2017 1:45 am
Hi there, I hope you are keeping well.
Just I would like to mention that I am using eviews 9.5 and when I wrote a code and I tried to do an arch test with more than 1lag it was not possible. The output is by default 1 lag. The execution program does not recognize this command, for example--> eq1.archtest(lags=5)
please your comments.
thanks.
MS
Re: fail arch test > 1 lag program
Postby EViews Gareth » Fri Jul 14, 2017 6:05 am
mkwazi
Postby mkwazi » Sat Jul 15, 2017 6:06 am
Hi, thanks for your response. However, I does not work. please check a couple of lines of mi code. attached.
I insist that the code not force to the lag dialog to put lag>1. Please correct me If I am wrong.
I await your comments.
MS.
eviews_forum_arch effect.prg
code arch effect
(614 Bytes) Downloaded 440 times
forum_eviews_archtest.xls
excel data
(462 KiB) Downloaded 425 times
Postby EViews Gareth » Sat Jul 15, 2017 6:26 am
You have a space between the command and its options.
mkwazi
Postby mkwazi » Sat Jul 15, 2017 9:24 am
ok, thanks. the Syntax archtest(options) es without space, which seems some different to the example. http://www.eviews.com/help/helpintro.ht ... htest.html
Regards,
MS
