Favar QUESTION
hamidlalkhezri
Re: Favar QUESTION
Postby hamidlalkhezri » Sun Apr 09, 2017 9:31 pm
I could not understand the questions. I never mentioned I(0) and I(1) factors. The add-in replicates Bernanke Boivin Eliasz (2005).
can You help me to find number of factors in Favar model?
dakila
Re: Favar QUESTION
Postby dakila » Mon Apr 10, 2017 2:31 pm
After the estimation, variables named _facrot1 _facrot2 ... will be created.
hamidlalkhezri
Re: Favar QUESTION
Postby hamidlalkhezri » Mon Apr 10, 2017 11:41 pm
aftar the estimation variables are create. now how i estimation FAVAR model?How to obtain the number of lags?
thank u.
hamidlalkhezri
Re: Favar QUESTION
Postby hamidlalkhezri » Tue Apr 25, 2017 12:04 pm
hi. can you help me to esimation favar model?
After estimating favar model this message appears:"Missing Value found in covariance/correlation matrix"
dakila
Re: Favar QUESTION
Postby dakila » Tue Apr 25, 2017 3:02 pm
Could you post the file?
ali_Economist
Re: Favar QUESTION
Postby ali_Economist » Sat Jul 08, 2017 12:11 pm
Hi, I am trying to run the model, if i use the dialog box it gives "Syntax error" if use the commandline it says tcode not define, i tried best to give the tcode by following the program codes but it still keep on giving error message. if you please help. filed attached.
germanyquarterly.wf1
(26.91 KiB) Downloaded 1375 times
ali_Economist
Re: Favar QUESTION
Postby ali_Economist » Thu Jul 13, 2017 1:34 am
Hi, i am trying to run the baysian favar, it is giving an error 500, if you please help.
Regards
Ali
(35.09 KiB) Downloaded 1338 times
ali_Economist
Re: Favar QUESTION
Postby ali_Economist » Thu Jul 13, 2017 2:05 am
got it sorted, please ignore my both questions about FAVAR and BFAVAR. thanks.
ouerk
Re: Favar QUESTION
Postby ouerk » Thu Jul 13, 2017 3:20 am
my "xdata" is a specific short term interest rate wich contain negatif values after 2010. this variable is stationnary after first difference transformation and i kwew that de tcode don't accept this transformation. I try to pass by Dlog but i can't (the value are negatif ,so i ca'nt transform them to log )
suggestions ??
thank you in advance !
Salima
dakila
Re: Favar QUESTION
Postby dakila » Thu Jul 13, 2017 5:41 pm
If I were you I will never transform interest rate. If you really want the first difference transformation, I will try to include it.
ouerk
Re: Favar QUESTION
Postby ouerk » Fri Jul 14, 2017 4:42 am
Thank you for your answer !you are right, i will not transform the interest rate for the study !
One last question , i would like to produce 'conditional forecasts' . I knew how to do it with simple Var but not with Favar .
it is possible to produce conditional forecast with FAVAR ?
Thank you !!
SALIMA
dakila
Re: Favar QUESTION
Postby dakila » Sat Jul 15, 2017 1:13 am
Yes. it is possible to estimate conditional forecast with the FAVAR add-in. You will need to install the Confcast add-in.
after the estimation you should use the following command (for BBE example):
First you will need to estimate the factor loading equation for selected variable (for example series108):
eq01.ls series108 _facrot1 _facrot2 _facrot3 ffr
then you should forecast the factors on conditional path of ffr :
favar01.confcast "ffr ffr" "2001m12 2002m6" "0.25 0.50"
finally you should forecast the selected variable (series108):
eq01.forecast
Keep in the mind all variables are standardized (zero mean and unit variance).
Therefore you should transform your variable back to the non-standardized one.
ouerk
Re: Favar QUESTION
Postby ouerk » Sat Jul 15, 2017 11:53 am
Thank you for your precious help !
For the study, i must compare the impact of "expansionary monetary policy shock' to show if the unconventional monetary policy and conventional monetary policy have the same impact .
The unconventional monetary policy consist to 'decrease 'policy rate since the crisis = exclusively 'expansionary moneraty policy" so i can't comment the impulse reponses of the selected variables to 'recessionary monetary policy shock' (+0.25 bps) like Bernanke.
is it possible to obtain impulse reponses of selected variable to 'expansionary monetary shock" (-0.25 bps or - 1 bps ) ??
Thank you in advance for your help !!
Salima
dakila
Re: Favar QUESTION
Postby dakila » Sun Jul 16, 2017 2:18 pm
Yes, it is possible. First you need to save the IRF. For instance:
favar(factor=3,horizon=48,rep=1000,ci=0.9,save=1) 13 xdata xslow xir tcode yx_name @ ffr
After the estimation you will need to calculate the unit IRF:
matrix irf_scl=irfxmat201/irfxmat201(1,1)
then scale it by parameter you want for example -0.25
irf_scl = irf_scl*(-0.25/ffr_std) irf_scl.line(m)
where ffr_std is standard deviaton of FFR. Keep in the mind the all variables are standardized so you need to standardize the shock.
ouerk
Re: Favar QUESTION
Postby ouerk » Wed Jul 19, 2017 4:04 am
thank you for your help, Dakila !!
i obtain impulse response matrix (for shock egal to -0,25) but i don't have confidence intervals , the axis 0 and the name of the selected variables (see workfile). what should i do to get these items (like figure 01 in your exple) ?
for the conditional forecast, i should transform for exple series2 to the non standardized on
-before i estimate eq01 ?
- before i forecast the factors ?
- before i forecast series2 ?
salima
graph.wf1
(22.83 KiB) Downloaded 1357 times
Return to “Add-in Support”
