Rolling Cointegration
pgupta
Postby pgupta » Fri Nov 22, 2013 3:45 am
Dear Gareth,
I tried to create a code to achieve three purposes:
1. Estimate rolling trace statistic
2) Estimate rolling "adjustment coefficients" of a VEC model.
3) Estimate rolling LR statistic for testing Weak Exogeneity of the ECM term in the VEC model.
Sir, while the code is working fine for the above stated requirements, I have one more requirement:
To store the standard errors and t-stat of these "rolling adjustment coefficients". I am not able to do this. I will be very obliged if you could please help me with this.
Thanks a ton!
rolling estimation.prg
(1.05 KiB) Downloaded 791 times
Re: Rolling Cointegration
Postby EViews Gareth » Sat Nov 23, 2013 11:42 am
What coefficients?
pgupta
Postby pgupta » Sun Nov 24, 2013 7:15 am
The adjustment coefficient (alpha) (A(1,1) in my case). As defined on Pg. 575 of Eviews 8 Users Guide II.
Postby EViews Gareth » Sun Nov 24, 2013 5:17 pm
You can probably get the standard errors from the coefficient standard errors matrix, v.@coefcov. You'll have to calculate the t-stats manually.
pgupta
Postby pgupta » Sun Nov 24, 2013 9:40 pm
Thank you Gareth! :)
fcb85
Postby fcb85 » Thu Jul 06, 2017 9:48 am
Dear Gareth,
I'm using similar code but for a larger sample (4157 observations, 8 variables) and smaller rolling window (500). Unfortunately the program does not run till the end of the sample, it turns "near singular matrix" error after 1100 replications. Do I have to define the matrix in a different manner? The same error is occurred when I use "pgupta" code
rolling cointegration.prg
(603 Bytes) Downloaded 605 times
Postby EViews Gareth » Thu Jul 06, 2017 10:31 am
Looks good to me.
fcb85
Postby fcb85 » Fri Jul 07, 2017 6:38 am
Then why it breaks out the code after 1100 replications, when normally it should perform 3657 replications. However, I've noticed that the break it varies if I change either number of variables or size of rolling window. Any support is more than welcome!
Postby EViews Gareth » Fri Jul 07, 2017 7:31 am
Your data probably results in a singular matrix.
