Identfifier as observation label scatter plot
stefanp
Postby stefanp » Wed May 24, 2017 1:11 am
Hi there,
I have a panel data set with two dimensions (in addition to time) with a specific identifier for each dimension. I want to create scatter plots and use one of the identifier series to label each observation in a scatter plot.
In know I can choose "Obs.Label" to add it, but that adds the joint identifier (for both dimensions) and the corresponding period.
Re: Identfifier as observation label scatter plot
Postby EViews Gareth » Wed May 24, 2017 7:10 am
Create an alpha series with the labels you want, then use
graph.setobslabel nameofseries
stefanp
Postby stefanp » Mon May 29, 2017 5:58 am
Not sure we are on the same page here:
That's what I do:
group temp a b freeze(graph) temp.scat(panel=stack) graph.setobslabel identifier
"identifier" is an alpha series. However, the plot appears without observation labels, only the standard circles are visible.
