Command to assign the highest of two series
Marc150
Postby Marc150 » Tue May 23, 2017 6:59 am
Is there a command to assign an observation the highest of two series?
So for example, suppose:
series a=1
series b=2
Is there then a command of the form
series c=@...(a,b)
which would return c=b, because b is greater than a?
In other languages the command 'max' often seems to do this. However, in EViews @max returns the maximum value within a vector.
Thanks,
Marc
Re: Command to assign the highest of two series
Postby EViews Gareth » Tue May 23, 2017 7:19 am
Series cc = @recode(a>b,a,b)
Marc150
Postby Marc150 » Wed May 24, 2017 8:51 am
Thank you.
What about in more general instances? For example, if I wanted to pull out the largest of a list of values, e.g., something of the form:
Series a=@...(b,c,..,z) that would assign a to be the highest of the values from b-z.
I suppose you could do some sort of nested for loop with the @recode command, but that seems unnecessarily complicated.
Postby EViews Gareth » Wed May 24, 2017 8:53 am
Put them in a group and use @rmax
