How to assign starting values to coefficient vector via Eviews Program command
acemi
Postby acemi » Wed May 03, 2017 12:50 am
I developed simple code to simulate values of Non Linear Least Squares NLS estimation coefficients.
Basically different range of starting values are defined for 5 coefficients, and both these values and the converged NLS coefficients estimates are recorded in matrix "results" row for each simulation value set.
My problem is to assign starting values into coefficient vector before each NLS estimation. The code I wrote for this starts with the text
"assign starting values to coefficient vector." but Eviews displays following error :
SHEET.(2,1)=0.1 is not a valid view for C in "DO_ C.SHEET.(2,1)=0.1".
Would very much appreciate any clues on this.
Many thanks in advance
acemi
fi_simul.prg
(1.39 KiB) Downloaded 305 times
simulasyon_eviews deneme data_fi.wf1
(7.67 MiB) Downloaded 253 times
Re: How to assign starting values to coefficient vector via Eviews Program command
Postby EViews Gareth » Wed May 03, 2017 2:39 am
C(2)=0.1
acemi
Postby acemi » Wed May 03, 2017 3:09 am
Thank you and silly me.
Now that I fixed this issue I run the program by setting "max number of errors before halting" = 20 from run prg dialog box.
But eviews stops way before at 2 iterations. How can I instruct it to run until it reaches prespecified error number ?
Thank you in advance again.
acemi
PS. updated prg file is attached.
(38.41 KiB) Downloaded 263 times
fi_simul.prg
(1.35 KiB) Downloaded 330 times
acemi
Postby acemi » Wed May 03, 2017 7:14 am
Hello again, fixed this issue via a if then else loop inspired from command and object user reference.
Thank you.
