I need to quickly export residuals of many different models. I would rather not go through the many windows to do this, but simply estimate a model and then directly load the residuals to a other program.
Question: Is the residual series stored somewhere in eviews directory so that I can load it directly without separate exporting procedure?
Access to residuals without exporting?
Re: Access to residuals without exporting?
Sorry I should have clarified better.resid
I want to access the residual outside the program without exporting. So I am asking if there is a file in the directory where the "resid" series is stored, so I won't need to separately export it, but only load it. I want to auto-export the residual series. It takes a lot of time to always do this separately...
EViews doesn't export anything automatically, so you'd have to give an instruction to save a series. An EViews program to do this probably wouldn't be very hard.
Yes, thank you this worked (the simple write command was enough).EViews doesn't export anything automatically, so you'd have to give an instruction to save a series. An EViews program to do this probably wouldn't be very hard.
