Generating lagged variables for panel data
Marc150
Postby Marc150 » Thu Apr 20, 2017 7:09 am
Is there something special that you have to do to generate lagged variables when using panel data?
When I try the very simple code
'series a=b(-1)' or
'genr a=b(-1)'
the series a ends up having a bunch of missing values, for reasons that I don't understand.
Thanks in advance,
Marc
Re: Generating lagged variables for panel data
Postby EViews Gareth » Thu Apr 20, 2017 7:13 am
No, nothing special. You are doing it correctly
Postby startz » Thu Apr 20, 2017 7:16 am
Remember that the first observation for each cross-section should be missing.
Marc150
Postby Marc150 » Thu Apr 20, 2017 7:29 am
Thanks (I've just realized that I was sampling only a subset of observations)
NeweyWest
Postby NeweyWest » Mon Dec 30, 2024 6:54 pm
In panel data, if I use series Y=X(-1), many cross-sections have missing data. If I try frml Y=X(-1), the first observation of each cross-section should be missing but it's not.
Postby startz » Mon Dec 30, 2024 7:11 pm
When I try, I get the correct NAs. What version are you using? Can you post a short example?
