eviews output? Where is it?
Eoghan
Postby Eoghan » Mon Mar 20, 2017 5:18 pm
I'm trying to get the p-value from my f-statistic.
I ran the command: !pval = @qfdist(.0319,3,1226) and eviews at the bottom left says !pval successfully computed
Where does the result go? I need what it computed
Re: eviews output? Where is it?
Postby EViews Gareth » Mon Mar 20, 2017 5:23 pm
It is stored in the program variable !pval.
Program variables disappear once the program has run.
If you want something permanent, use a scalar object instead
Eoghan
Postby Eoghan » Mon Mar 20, 2017 5:28 pm
I tried scalar pvalue=!pval=..... but that says !pval not defined now
Postby EViews Gareth » Mon Mar 20, 2017 7:46 pm
Did you define it in your program?
EViews Matt
Postby EViews Matt » Tue Mar 21, 2017 8:44 am
The syntax "pvalue = !pval = @qfdist(.0319,3,1226)" tests whether !pval is equal to @qfdist(.0319,3,1226) and assigns that true/false result to pvalue, it does not assign the value returned by @qfdist to both !pval and pvalue. It sounds like "pvalue = @qfdist(.0319,3,1226)" is what you want.
