NA in series
stefanp
NA in series
Postby stefanp » Mon Mar 13, 2017 9:10 am
Hey there,
I have a series that, on purpose, contains a couple of "NA"s.
I need to extract the numerical value from series A if series B assumes the smallest value. This value in turn should be assigned to a scalar. I though of something like this
if B=@minsby(B,identifier) then scalar=A endif
However, I end up with the found NA in matrix error message. Any ideas how to proceed?
Re: NA in series
Postby EViews Gareth » Mon Mar 13, 2017 9:15 am
Not entirely sure I follow, but I think something like:
smpl if b=@min(b) scalar myscalar = @min(a)
(note that second @min is arbitrary).
stefanp
Re: NA in series
Postby stefanp » Mon Mar 13, 2017 9:39 am
I am using a Panel and hence, each cross-section has its own minimum. Since I am looping through the cross-sections, I thought @minsby instead of @mins would be appropriate because the former allows to specify an identifier.
is there another way to solve my problem without changing the current sample?
Re: NA in series
Postby EViews Gareth » Mon Mar 13, 2017 9:54 am
Can you describe in words what you're trying to do?
If there's a panel, why is there a scalar? What are you taking the minimum over? (Time, cross-sections, both?)
