Changing the Convert Hilo Attribute
BigD
Postby BigD » Thu Mar 02, 2017 9:42 am
I want to change the metadata in the Convert Hilo Attribute such as average => sum. But I am unable to as I get a message saying that it can't be modified. Is there another way to change it other than to replace it? It is because some methods of conversion isn't always by average.
Or do we get a choice of changing the default to something else when we actually convert?
Thanks.
Re: Changing the Convert Hilo Attribute
Postby EViews Gareth » Thu Mar 02, 2017 9:49 am
Can you provide more information?
Where are you trying to change it? On what type of object?
BigD
Postby BigD » Thu Mar 02, 2017 9:52 am
I'm adding some attributes to a database. And I noticed that one of the default ones (that was already there) is called Convert Hilo. I wanted to change it to something like the Conversion Technique beside it.
I've attached a picture to provide a visual aid. I've moved the series into a workfile in order to import some attributes.
Convert hilo.PNG (79.21 KiB) Viewed 6775 times
Postby EViews Gareth » Thu Mar 02, 2017 9:55 am
You can't change anything directly in the database. You'll have to fetch it into a workfile, change the attribute then send it back.
BigD
Postby BigD » Thu Mar 02, 2017 10:01 am
Yes, I've moved it into a workfile to change the attributes. But I can't change convert hilo (I believe it is an attribute already added by Eviews like freq). It just says I can't modify it.
Here's another image:
convert hilo2.PNG (62.92 KiB) Viewed 6769 times
Postby EViews Gareth » Thu Mar 02, 2017 10:07 am
Did you bring it in as a series or as a link?
BigD
Postby BigD » Thu Mar 02, 2017 10:13 am
Series. I fetched them from the database.
Postby EViews Jason » Thu Mar 02, 2017 10:43 am
When modifying attribute values from the workfile window, you are attempting to modify the values for all the listed objects. We currently do not allow the modification of particular attributes for a set of the objects from the workfile window. Attributes such as 'Description' may be modified but not conversion methods.
You will have to change the value for each individual series. This can be done by opening the series and selecting Properties->Freq Convert.
BigD
Postby BigD » Thu Mar 02, 2017 12:53 pm
Thanks for the clarification. I'll keep this in mind. Appreciate it!
