Dear Sir/Madam, I want to do rolling estimations of a fixed effects model in a pool object. I need to calculate the long run elasticity, and compute the confidence band. What I thought I would do is a Wald test, which will give the value and standard error. But how can I store the value and se from the Wald test for each rolling estimation, and store them into series for plotting? Or are there alternative ways in Eviews to obtaining standard errors for long run elasticity and easily store them so that they can be saved as rolling regression coefficient statistics?
So for example: in the attached file, I estimate this:
smpl 1994Q1 @last
p_ae.ls(cx=f) cpi? c cpi?(-1) ppi_inf?(0 to -3)
p_ae.wald c(3)/(1-c(2))=0
So I get the long run elasticity as c(3)/(1-c(2))=0 and se from the table. See below:
Normalized Restriction (= 0) Value Std. Err.
C(3) / (1 - C(2)) 0.910706 0.088253
But how can I store the two figures for each estimation period? Any alternative way of obtaining the standard error?
Really appreciate your help.
Best,
chang
store Wald test value and se
- rolling.wf1
- (212.48 KiB) Downloaded 307 times
Re: store Wald test value and se
Dear Gareth, many thanks for this. Very useful.
I have a related question. Is there a direct way of storing an explanatory variable's standard errors from a pooled object (using FE estimator)?
I estimate (p_ae being a pooled object)
Then I can get the coefficient by simply do:
scalar coef1=c(3)
But I don't know how to retrieve the se for c(3).
When I do:
scalar test=@stderrs(3)
The error message says 'no equation in memory'.
If I do
scalar test=p_ae.stderrs(3)
Then the error message says 'stderrs is not a member or procedure for p_ae'.
What can I do? Again convert to a table for storing data?
Best,
chang
scalar coef1=c(3)
When I do:
If I do
Best,
chang
- rolling.wf1
- (212.48 KiB) Downloaded 312 times
I still don't know how to refer to the standard errors of a variable in a pool regression.
I did this (p_ae is the pooled object):
scalar test=p_ae@stderrs(2)
I get the error 'syntax error'. How can I write the command to get the standard error for cpi(-1)?
chang
chang
You're missing a ".".
scalar test=p_ae.@stderrs(2)
Got it. Many thanks Gareth. Chang
