Restricting the dependent variable
jacarandas
Postby jacarandas » Mon Jan 16, 2017 10:11 pm
So, I have been trying to figure this out. I know it's possible to impose restrictions on the coefficients of the independent variables. But, is there any way to have a constraint on the dependent variables of a model of equations, in which all the dependent variables must sum up to 1 by construct?
Thanks!
Re: Restricting the dependent variable
Postby EViews Gareth » Mon Jan 16, 2017 10:47 pm
This makes very little sense. Can you explain what you mean in more detail?
jacarandas
Postby jacarandas » Mon Jan 16, 2017 10:55 pm
I've a set of ratios that sums up to 1 in history. I would like to forecast them ahead of time. But, how do I ensure that these forecast ratios in the model sums up to 1 and remain positive? Is there an estimation method I can use or an identity I can append to my model?
Currently, I am using a least square estimation to forecast ahead.
I know I am able to restrict coefficients on independent variables. But, I don't know if the same thing works for forecasts/dependent variables.
Thanks!
KrilleJ
Postby KrilleJ » Wed Jan 18, 2017 5:44 am
Perhaps logit-type specifications could work:
fraction_i=exp(x_i*beta_i)/exp(sum_i x_i*beta_i)
/K
