"Next found outside of loop" Error
luca1s
Postby luca1s » Sun Dec 04, 2016 3:51 pm
Hi all
I'm trying to run a loop of very simple AR(4) regressions for a group (named "pct"), for which I want to save the impulse responses of each series on itself. The responses are to be stored in a matrix titled "ar4". I have written the code below, but whenever I run it there is a "Next found outside of loop" error. Without the next argument it works, but obviously stops at the first variable in the group pct. Any thoughts on what is causing this issue? Thanks in advance
group pct
%v = @wlookup("pct*", "series")
pct.add {%v}
matrix (12,100) ar4
for !i to pct.@count
%name = pct.@seriesname (!i)
var test.ls 1 4 {%name}
test.impulse(12, m ,imp=gen,matbyr=temp) {%name} @ {%name}
colplace(ar4, temp, !i)
d temp
stop
dakila
Re: "Next found outside of loop" Error
Postby dakila » Sun Dec 04, 2016 4:18 pm
change
to
for !i=1 to pct.@count
luca1s
Postby luca1s » Sun Dec 04, 2016 4:34 pm
Thanks for the quick reply, apologies but this was a typo in the request on the forum (instead of copy paste-ing, I retyped it a bit too hastily).
The program actually was written containing your suggestion.
Nonetheless the Error occurred.
group pct
pct.add {%v}
matrix (12,100) ar4
d temp
stop
Postby EViews Gareth » Sun Dec 04, 2016 5:21 pm
create u 100 for !i=1 to 10 series pct!i=nrnd next group pct %v = @wlookup("pct*", "series") pct.add {%v} matrix (12,100) ar4 for !i=1 to pct.@count %name = pct.@seriesname (!i) var test.ls 1 4 {%name} test.impulse(12, m ,imp=gen,matbyr=temp) {%name} @ {%name} colplace(ar4, temp, !i) d temp next
Works fine.
luca1s
Postby luca1s » Sun Dec 04, 2016 5:30 pm
Following you reply, I created a new program file to re-test the code using my own data, and weirdly enough now it did work. I'm not sure what corrupted the other file, but I won't lose any more time on it. Given that I already lost some time on something that could be solved so simply, I am equally thankful to you, as embarrassed to have come to the forum with this.
My apologies, and again many thanks for the responses.
