Directory name is invalid?
chester
Postby chester » Wed Nov 30, 2016 2:06 pm
Unable to create process: The directory name is invalid.
I am trying to use the spawn command to execute a Python script from my EViews program.
The file directory clearly exists as I am in it right now.
What could possibly be the reason here? Code below:
%command = " python ""P:\Folder1\Folder2\script.py"" "+ """"+vectorStr+"""" spawn {%command}
EViews Matt
Re: Directory name is invalid?
Postby EViews Matt » Wed Nov 30, 2016 2:56 pm
My first thought is that this is an issue with launching python, not your python script. Perhaps the python installer didn't add its executables directory to the PATH environment variable. As a quick check, try opening a command prompt and running the command "python". An error about python not being a recognized command will verify a PATH issue. An easy fix in EViews is to always use the full path to the python executable instead of just "python".
