Command for shading areas using intraday data
asbatronic2016
Postby asbatronic2016 » Thu Nov 10, 2016 2:35 pm
I have minute by minute data for equity prices for May 06, 2010 between 7:00:00 and 15:59:59.
I want to use a command to insert a shaded area between 08:00:00 and 09:00:00 but it does not work.
I used the following command:
graph graph3.line price
graph3.draw(shade, bottom) 05/06/2010 08:00:00 05/06/2010 09:00:00
I can draw shaded areas using the vertical axis but it looks like Eviews is unable to read correctly the date/time specification.
Thanks in advance
Example.WF1
(21.21 KiB) Downloaded 233 times
Re: Command for shading areas using intraday data
Postby EViews Jason » Fri Nov 11, 2016 11:45 am
Try putting the dates in quotes.
graph3.draw(shade, bottom) "05/06/2010 08:00:00" "05/06/2010 09:00:00"
asbatronic2016
Postby asbatronic2016 » Fri Nov 11, 2016 11:54 am
Thanks it worked!
Cheers
