Data converting incorrectly
miorinnovo
Postby miorinnovo » Wed Oct 26, 2016 10:56 am
I am running a program that is fetching a daily data series into a quarterly workfile. The default conversion is set to average, which is what I want, but it seems to be adding the daily data instead. Is there a way to get around this problem and forcing an average? Thanks
Re: Data converting incorrectly
Postby EViews Gareth » Wed Oct 26, 2016 11:12 am
Hard to say what's going wrong without seeing what's going on.
Salguod
Postby Salguod » Mon Nov 07, 2016 1:14 pm
Hi. I am finding difficulty with converting low to high frequency data using balanced panel data.
If the data ever converts, it doesn't correspond with the original cross id. The country object label on an annual basis doesn't translate into a new converted high frequency with its corresponding names. Then there is the problem of how to make sure that the converted data corresponds with the designated country . I may start with an annual series where no 1 Argentina, 2 Brazil, 3 Canada and so on. After the conversion is done I get either a string of NAs stacked , no country names appear in the country column, just numbers and whats worse the converted results don't even add up to the sum original numbers. In fact during an annual to quarterly conversion, the converted figures are frequently larger than the original figure, suggesting that quarterly cross ids don't match to their corresponding country name.
The user's manual doesn't accurately create a new page from a clean worksheet, which is not realistic to say the least.
Thanks in advance for your assistance.
How can I contact you directly? Best
Thanks for the assistance.
Postby EViews Gareth » Mon Nov 07, 2016 5:59 pm
We'd need to see what's going on.
You can email support@eviews.com, but you'll need to include your EViews serial number.
