AR1 process in order to show a converging process
ecofine
Postby ecofine » Wed Oct 19, 2016 5:48 am
Hello.
I am trying to draw a converging process of AR1 process as below:
But this graph does not converge to a point. Can you help me about whether this is a mistake or
simply a matter of plotting technique. If you know how to make a converging graph, please let me know!
Thank you!
IH
wfcreate smpl u 100
smpl @first @first
series y = 0
smpl @first+1 @last
series i=@rnd
series y =0.9*y(-1)+ i
series dy=y-y(-1)
plot y
plot dy
Re: AR1 process in order to show a converging process
Postby EViews Gareth » Wed Oct 19, 2016 7:51 am
You might need to describe what you think the program is doing before we can judge if it is actually doing it or not.
Postby startz » Wed Oct 19, 2016 8:33 am
My guess is that you wanted mean zero errors. The function @rnd (which isn't in the manual but which appears to be equivalent to rnd) generates uniform(0,1) draws.
ecofine
Postby ecofine » Sun Oct 23, 2016 10:51 am
Thank you for your good comments!
I found that I have to write the solution of differential equation of AR(1) model in order to show a convergence.
It is like, y=o,9^t.
