When doing stochastic simulation in a model, I find that the confidence bounds are too wide. Here are two examples:
If I simulate from the uniform distribution using the following:
r1=rnd
I obtain 90% confidence bounds that are outside of the support of the distribution. The simulated bounds are approximately -.32 and 1.32.
If I simulate from the standard normal distribution using
r2=nrnd
I obtain 90% confidence bounds that are too wide, approximately -2.9 and +2.9
I am using Eviews 9. Please advise. Thanks.
Possible Bug in Model Simulation
Re: Possible Bug in Model Simulation
I think you're forgetting to include the innovations in your interpretation of what the bounds should be.
Could you elaborate Gareth. I've read the discussion of simulation in the help file and may not be understanding how the simulation works. I thought the simulation of r1=rnd in a model object would draw 1,000 observations from the [0,1] uniform distribution and then compute the confidence bounds from that simulation. (By the way, if it matters, I'm using Stochastic Static simulation.) Thanks.
Each equation in the model, unless it is specified as an identity, has an implicit error term on the end. So your line:
is actually:
where the stochastic solve is generating the nrnd part.
r1 = rnd
r1 = rnd + nrnd
I understand. Is there a workaround? If I use
@identity r1=rnd
I get an error message: "Matrix or vector given non positive dimension"
It may help if I provide more background. In an earlier post on simulating from a discrete distribution, a contributor named Glenn responded to my post and suggested the following two lines of code to simulate from a discrete distribution. I thought this was an appealing way to proceed but, when I implemented it, I found that this did not produce the correct discrete distribution. I now understand why, but I am not sure how to get around this problem.
z = rnd
@identity w = 8 * (z<.2) + 10 * (z<.3 and z>=.2) + 15 * (z<.55 and z>=.3) + 17 * (z<.72 and z>=.55) + 22 * (z>=.72)
@identity r1=rnd
z = rnd
Ah, sorry, it's the extra nrnd at the end of the Z which I didn't think about. Let us think about this for a bit.
Try using:
which should multiply the innovation covariance matrix by (essentially) zero, meaning the innovations become tiny.
m.stochastic(m=1e-16)
Glenn pointed out another trick that is slightly better:
r2 gets generated with a variance of 1 from the normal. The cnorm of a normal returns a uniform.
model m
m.append r2=0
m.append @innov r2 1
m.append @identity r1 = @cnorm(r2)
m.solve(s=a)
Note that the R1 in Gareth's snippet gives you the Z from above which you'll feed into the other identity.
@identity w = 8 * (z<.2) + 10 * (z<.3 and z>=.2) + 15 * (z<.55 and z>=.3) + 17 * (z<.72 and z>=.55) + 22 * (z>=.72)Re: Possible Bug in Model Simulation
Thank you both. I really appreciate the help!
