Coefficients estimation
E-mily
Postby E-mily » Sun Oct 02, 2016 3:35 am
Hello everyone, I'm new here and hope you can give me a hand with my problem.
Why do the p-values of my MEAN's coefficients change when I estimate a (G)ARCH model?
Shouldn't Eviews be only working with the residuals of that MEAN?
I hope I've been clear
Re: Coefficients estimation
Postby startz » Sun Oct 02, 2016 7:16 am
The "H" in ARCH stands for heteroskedasticity. That affects standard errors.
E-mily
Postby E-mily » Sun Oct 02, 2016 9:38 am
I see startz, thanks.
So, if I want to choose the equation of the mean, I should do that with the ARCH method (in Estimation Setting) and not choose the equation for the mean FIRST(using ols or arma method) and then estimate the garch.
Postby startz » Sun Oct 02, 2016 10:03 am
That's right. The mean equation and ARCH are estimated together.
E-mily
Postby E-mily » Sun Oct 02, 2016 11:15 am
Ook, thanks :*
It is a bit odd, if I might, anyway. :roll: Because if there is autocorrelation in the series you may want to correct it BEFORE you run your garch model, otherwise the estimation may be altered.
Postby startz » Sun Oct 02, 2016 11:19 am
Nothing stops you from correcting for serial correlation in the mean equation during ARCH estimation. Just include AR(1) (or whatever) in the specification.
E-mily
Postby E-mily » Sat Oct 08, 2016 6:15 am
I know that ARCH family is used to model time-varying volatility, but would it be okay if I just developed it in order to see the significance and "the impact" of an independent variable over the dependent one?
I could do it with an ordinary regression, but I would have to face heteroskedasticity which could alter its parameters and may lead to false results.
Postby startz » Sat Oct 08, 2016 6:57 am
Totally fine
E-mily
Postby E-mily » Sun Dec 11, 2016 10:31 am
@startz
Just to be perfectly clear, is there any difference between an ARMA and an ARMA-GARCH model as far as the mean equation is concerned?
Postby startz » Sun Dec 11, 2016 10:56 am
The difference is that ARCH gives a GLS-like estimate correcting for time-varying heteroskedasticity, which seems to be what you want.
E-mily
Postby E-mily » Sun Dec 11, 2016 11:33 am
Does that mean that the coefficients estimation is more precise?
Postby startz » Sun Dec 11, 2016 11:34 am
Yes, it does.
