From numbers to letters
Postby tvonbrasch » Thu Sep 29, 2016 12:56 am
how can I go from a number to a letter in the alphabet?
I have a loop where i have identfied that i want to set a line in column 2. but when using the setlines command I have to specify this as column B, and not column 2.
table.setlines(B) +r
If I know the number of the column I want to change, how can I easily find the appropriate letter representing that column using program code?
Re: From numbers to letters
Postby tvonbrasch » Thu Sep 29, 2016 11:44 pm
The best way I have found so far is to do it manually
for %col %letter 1 A 2 B 3 C 4 D 5 E 6 F .... next
johansamuelsson
Contact:
Postby johansamuelsson » Fri Sep 30, 2016 7:44 am
Use @chr
For !i = 1 To 26 %cl{!i} = @Chr(!i+64) Next table.setlines({%cl2}) +r
Regards Johan
Postby tvonbrasch » Fri Sep 30, 2016 9:06 am
Perfect Johan, thanks!
