@wdrop statement
Andre2016
@wdrop statement
Postby Andre2016 » Fri Sep 23, 2016 1:07 pm
Hello Guys,
So I have the following code :
smpl @all genr bbmodel = bbdmodel alpha bbmodel @wdrop ("Astra 1125SP" , "SP") @wdrop ("Astra 1125SPX" , "SPX")
Is there a way to write it so that I don't have to revrite the @wdrop statement on every single line?
Re: @wdrop statement
Postby EViews Gareth » Fri Sep 23, 2016 1:47 pm
Currently those lines are not doing anything, so hard so see what you mean.
Andre2016
Postby Andre2016 » Mon Sep 26, 2016 11:23 am
I have a series called "bbmodel" which is an alpha series that I'd like to edit.
In that alpha series I'd like the following action:
If what appears is "Astra 1125SP" then I'd like it to be only "Astra 1125"
If what appears is "Astra 1125SPX" then I'd like it to be only "Astra 1125"
Postby EViews Gareth » Mon Sep 26, 2016 11:34 am
bbmodel = @replace(bbmodel, "SPX", "")
Andre2016
Postby Andre2016 » Mon Sep 26, 2016 11:37 am
Thanks Gareth,
Andre2016
Postby Andre2016 » Tue Oct 04, 2016 1:27 pm
I have an issue.
when I do
bbmodel = @replace(bbmodel, "Falcon 200", "Falcon 20")
All the values containing "Falcon 200***" changes e.g:
Falcon 2000S becomes Falcon 200S
Is there a solution so that when I change "Falcon 200" to "Falcon 20", everything else remain the same ?
Thnks
Postby EViews Gareth » Tue Oct 04, 2016 2:01 pm
If there are spaces after the 200, you could include a space in the replace.
Otherwise you'll have to do a search replace with @instr, @left, @mid etc...
