Unbalance Panel: Fixed Effects
de726
Postby de726 » Mon Sep 19, 2016 10:50 am
I'm trying to extract both fixed effect values and the name of variables assigned to it.
In the program, I've used "eq1.@effects" to extract the fixed effect estimation but can't find a way to extract the variables name.
I have unbalance panel so these variables name changes with each iterations. Would really appreciate the help.
Thank you.
Re: Unbalance Panel: Fixed Effects
Postby EViews Gareth » Mon Sep 19, 2016 11:25 am
I don't understand what you mean by "variables assigned to it"?
de726
Postby de726 » Mon Sep 19, 2016 11:54 am
For example, after you estimate a cross section fixed effect equation and click on the output window "View" > "Fixed/Random Effect" > "Cross section effect" you will get something like this >>
Country Effect
US 1.1
UK 1.2
Japan 1.3
I'm trying to get both country names and the fixed effect coefficient for each iterations.
I have unbalance panel so the problem I'm having is that the number of countries and its name will varies when I run the program.
Postby EViews Gareth » Mon Sep 19, 2016 12:01 pm
Freeze the output into a table and use that.
freeze(mytab) eq1.effects
de726
Postby de726 » Mon Sep 19, 2016 3:42 pm
It works, thank you!
