Table to PDF
Table to PDF
Postby tvonbrasch » Fri Sep 16, 2016 3:27 am
I have created a table named _hovedtabell:
when I use the command
_hovedtabell.save(t=pdf, size=A4, leftmargin=0.01, rightmargin=0.1, topmargin=0.3, bottommargin=0.3) ..\KVARTS\resultater\test.pdf
the entire table comes out in bold font in the pdf document
what is causing this?
To set the years in bold font i used the command
_hovedtabell.setfont(1) +b
. I believe this command is causing the error, because if I comment out this command, there is no problem when saving the table as a pdf document i.e. none of the characters are then written in bold.
Re: Table to PDF
Postby EViews Jason » Fri Sep 16, 2016 10:22 am
We can't replicate this one. Please send your workfile and the created pdf to support@eviews.com and reference this thread.
Re: Table to PDF
Postby tvonbrasch » Sun Sep 18, 2016 10:17 pm
Okey, I have sent the files to you. My Eviews version is 9.5 sep 9 2016.
