Five Year Average in Panel Data
abdurrub
Postby abdurrub » Mon Aug 12, 2013 1:02 pm
I am struggling in creating 5-year averages for every cross section in my panel data.
Any help will be appreciated.
Cross Sections: Countries (189)
Time: years (1950-2010)
abdurrub
Re: Five Year Average in Panel Data
Postby abdurrub » Mon Aug 12, 2013 1:17 pm
I somehow managed to convert the BALANCED panel data into averages. Now I am only struggling with how to do the UNBALANCED.
Postby EViews Gareth » Mon Aug 12, 2013 1:20 pm
series fiveyears = @recode(@mod(year,5)=0, year, fiveyears(-1)) series means = @meansby(y, fiveyears, @crossid)
abdurrub
Postby abdurrub » Mon Aug 12, 2013 1:29 pm
I am a beginner, would it be possible if you could explain how to go about the code? I wrote it on the command bar and two var FIVEYEARS and MEANS were made. How to put the observation values in these?
I am sorry, you may not reply to this if I am asking too much.
Thanks a lot for ur reply anyways.
Postby EViews Gareth » Mon Aug 12, 2013 1:37 pm
The series fiveyear that gets created is just a variable equal to "1950" for the first five years, equal to "1955" for the next five years, and so on.
The series means contains the averages.
AngieL
Postby AngieL » Mon Aug 15, 2016 9:35 am
Hi there,
I have the same problem I tried the formula but I need to do it for every single explanatory variable but the numbers won't change.
Is there another formula I need to use to do for every variable (apart from changing the name in the formula which I have done but it is not working) ?
Thanks,
Angie
Postby EViews Gareth » Mon Aug 15, 2016 10:01 am
No.
You can write a loop that will loop through the variables and create the average.
AngieL
Postby AngieL » Tue Aug 16, 2016 4:43 am
Hi Gareth,
Thank you for your response. Can you please elaborate because I can not understand?
Thank you,
Angie
Postby EViews Gareth » Tue Aug 16, 2016 7:38 am
You know how to create the five year average for one series, you want to know how to do it for multiple series. I merely stated that you can write a for loop that loops through all your series one at a time and performs the averaging. The programming forum has lots of examples of using for loops.
