WFOPEN function on CSV file changes column data type
tchaithonov
Postby tchaithonov » Wed Jul 27, 2016 8:38 am
Hi All,
I am still using EViews 8.1 and I have this question I don't seem to have a way to solve.
I wrote a program that sucks in csv files (panel datasets with date id and cross id columns) into eviews, convert them into dated panel using pagestruct, but before I could do anything, I found out that the supposedly string cross id column has been converted into series by Eviews.
I understand that it's because I have a mixture of double quoted numerics and characters, and the latter don't appear until the end of the dataset.
I read the wfopen help page carefully, and saw that there is a quotes=double for html files, but I can't seem to make it work for csv's. The other way I see is to predefine the column type (using format=(A3), for instance), but I have csv files with different number of columns (more than 50+ files) and I can't predefine them all before I imported them.
Is there a way to solve this?
Thanks.
Tchaithonov
Re: WFOPEN function on CSV file changes column data type
Postby EViews Gareth » Wed Jul 27, 2016 9:48 am
You can try using the scan=all argument.
tchaithonov
Postby tchaithonov » Wed Jul 27, 2016 11:02 am
Hi Gareth,
Thanks for the suggestion, but it doesn't seem to work.
I tried this:
wfopen(scan=all) {%file}
it seems gives me a series for that column with NAs replacing all the characters.
Am I doing anything wrong with that code? Please let me know. Thanks.
Philip
Postby EViews Gareth » Wed Jul 27, 2016 11:46 am
tchaithonov
Postby tchaithonov » Wed Jul 27, 2016 12:17 pm
Yeah, I actually tried both ways
wfopen(scan=all) {%file} ' which I showed above wfopen {%file} scan=all
Not working.
Postby EViews Gareth » Thu Jul 28, 2016 8:48 am
We'd need to see the file.
