Hi!
I have to run Orthogonalized Impulse Response in Eviews? How can I do it? Is it a special function?
Re: Orthogonalized Impulse Response
Use impulse command after estimation of VAR.
For example, var01.impulse
Thanks!
I just thought that is something different.
By the way, how can I check the significance of the impulse response? I have only one lag, so can I use Granger-causality test?
var01.impulse(20, se=a)
Yes, you can do Granger causality test.
