Centering objects in a spool printed to PDF
glockner
Postby glockner » Fri Jul 22, 2016 6:41 am
Hello, is there a way to center objects in a spool that is printed to PDF using the following notation?:
{spool}.save(t=pdf,landscape)
I see that you can adjust the margins, but this does not center all objects if you have objects of varying size in the spool. Thanks.
Re: Centering objects in a spool printed to PDF
Postby EViews Jason » Fri Jul 22, 2016 11:16 am
Apparently there isnt a way to change the justification when saving to PDF. We will add to our list of features to add.
If you have a PDF printer driver such as the Adobe PDF or CutePDF, you can print to PDF and set the justification then.
