Apparent bug in automatic scaling of dual scales
If you graph a group with scales on both left and right and click overlap, the automatic scaling on the right gets screwed up.
Re: Apparent bug in automatic scaling of dual scales
Can you post a screenshot of the problem?
Right axis should be 1 to 0.
Are you commenting on the fact that the scale range changes depending on whether or not overlap is on vs off?
No, the issue is that the scaling for the red line makes no sense given the values the red line takes on.Are you commenting on the fact that the scale range changes depending on whether or not overlap is on vs off?
Please send us your workfile. Thanks
Page Spain
- pwt81.wf1
- (3.69 MiB) Downloaded 365 times
