I used this code: factor dmf1.ipf(n=mineigen) a b c d e f g
to generate a factor. What I am really interested in are principal components, which I can only get (to my knowledge) by clicking View->Eigenvalues-> and click Eigenvectors in additional output section. I want to save first one or two principal components of Eigenvector (loadings) table into my workfile. I tried using factor.eigen(eigvec)function, but it only gave me eigenvalues, not vectors (that I want). Could you let me know how I can do that using code? Thanks in advance.
Principal Component Analysis (Eigenvector Extracting)
- Capture.PNG (37.89 KiB) Viewed 5430 times
Re: Principal Component Analysis (Eigenvector Extracting)
Do you just want the eigenvectors and eigenvalues of a covariance matrix? If so, factor analysis may not be what you want.
Would there be an alternative way to get the data? Or is there any way I can extract underlying factors from the output? Thanks.
Use makepcomp,
http://www.eviews.com/help/helpintro.ht ... pcomp.html
or interactively, using from a group using View/Make Principal Components...
