Johansen Cointegration Test Coefficents vs. OLS Coefficients
kszynkar
Postby kszynkar » Thu Jun 23, 2016 1:26 am
This is probably a silly question, but I have two series that are cointegrated. When I run the cointegration test, the Johansen normalized cointegrating coefficients are different from the coefficients I get using an OLS. Shouldn't these be the same?
kszynkar
Re: Johansen Cointegration Test Coefficents vs. OLS Coeffici
Postby kszynkar » Fri Jun 24, 2016 10:20 am
Does my question make sense, or should I provide more details?
dakila
Postby dakila » Fri Jun 24, 2016 2:15 pm
For large samples EG will converge to Johansen results. For small sample EG will suffer from endogeneity and serial correlation problem. If you want to use single equation method, it is better to try Stock-Watson or FMOLS.
kszynkar
Postby kszynkar » Sun Jun 26, 2016 11:00 pm
ahhh. Thank you
